Vault Customization
Share your knowledge, ask questions, and explore popular Vault API, Data Standard, and VBA topics related to programming, creating add-ins, or working with the Vault API.
File Associations at AddFile
4 REPLIES 4
dominiekvanwest
720 Views, 4 Replies
I want to add a file to the Vault that has an attachment. So I first add the attachment and then I want to add the file with an association to the attachment. I use the following code:
WebServicesByteArray.Bytes = System.IO.File.ReadAllBytes(LibrarymapLocal & "Test.ipt.dwf")
serviceManager.DocumentService.AddFile(folder.Id, Test.ipt.dwf", "", System.IO.File.GetLastWriteTime(LibrarymapLocal & "Test.ipt.dwf"), Nothing, Nothing, DocumentService.FileClassification.None, True, WebServicesByteArray)
WebServicesByteArray.Bytes = System.IO.File.ReadAllBytes(LibrarymapLocal & "Test.ipt")
Dim Association(0) As Autodesk.Connectivity.WebServices.FileAssocParam
Association(0).CldFileId = fileId
Association(0).ExpectedVaultPath = Librarymap
Association(0).Typ = AssociationType.Attachment
serviceManager.DocumentService.AddFile(folder.Id, "Test.ipt", "", System.IO.File.GetLastWriteTime(LibrarymapLocal & "Test.ipt"), Association, Nothing, DocumentService.FileClassification.None, False, WebServicesByteArray)
But I get an error (System.NullReferenceException) at: Association(0).CldFileId=fileId
What am I doing wrong? What's the correct way to add a file with an attachment? (The (0) is there because it has to be an array)
Thanks in advance!
Dominiek
4 REPLIES 4
Redmond.D
in reply to: dominiekvanwest
You declared the array, but you need to create a new object to fill it.  Try adding the following line:
Association(0) = new Autodesk.Connectivity.WebServices.FileAssocParam()
Doug Redmond
Software Engineer
dominiekvanwest
in reply to: Redmond.D
Thank you for your quick reply.
This does it!
Just wondering, if the array contains more than 1 element, I'll need to do this for every item in the array? So something like this:
For i as Integer = 0 to Association.Length - 1
Next i
Redmond.D
Correct.  Except your would use Association(i) inside the loop, not Association(0)
Doug Redmond
Software Engineer
dominiekvanwest
Oh, yeah, off course with i instead of 0. Just typed it in here without checking 🙂
Thank you very much for the help!
