Hi, is it possible with the vault Pro 2015 to export our UI customization. For example if i have added some columns, can i export or take an xml somewhere to export on the other computers?
Solved by orbjeff. Go to Solution.
You may want to check out Doug Redmonds "Project Thunderdome" if you want to deploy various custom UI settings to your end users.
Here is the link to his blog post: http://justonesandzeros.typepad.com/blog/2013/05/project-thunderdome-2014.html
I would suggest installing it via the autodesk exchange app store here: https://apps.exchange.autodesk.com/VLTC/en/Detail/Index?id=appstore.exchange.autodesk.com:vault2015p...
