Vault Customization
Share your knowledge, ask questions, and explore popular Vault API, Data Standard, and VBA topics related to programming, creating add-ins, or working with the Vault API.
Export UI in Vault Pro 2015
2 REPLIES 2
eric.paris
442 Views, 2 Replies
Hi, is it possible with the vault Pro 2015 to export our UI customization. For example if i have added some columns, can i export or take an xml somewhere to export on the other computers?
2 REPLIES 2
orbjeff
in reply to: eric.paris
You may want to check out Doug Redmonds "Project Thunderdome" if you want to deploy various custom UI settings to your end users.
Here is the link to his blog post: http://justonesandzeros.typepad.com/blog/2013/05/project-thunderdome-2014.html
I would suggest installing it via the autodesk exchange app store here: https://apps.exchange.autodesk.com/VLTC/en/Detail/Index?id=appstore.exchange.autodesk.com:vault2015p...
Jeff Johnson
Technical Consultant
MasterGraphics Inc.
eric.paris
in reply to: orbjeff
Thank you very much!
