In a tileblock field we want to use a diesel expression to show the first capital of the drawing state(istorical).
This is a part of a fully automated ID representation of a drawing.
What it looks like see attachement.
What i use for these fields in the block attribute you see here:
%<\AcVar CustomDP.Project number \f "%tc3">%-%<\AcVar CustomDP.Document type \f "%tc3">%-%<\AcDiesel $(substr,%<\AcVar CustomDP.Status>%,1,1)>%%<\AcVar CustomDP.Revision \f "%tc3">%-%<\AcVar CustomDP.Discipline \f "%tc3">%-%<\AcVar CustomDP.Project phase \f "%tc3">%-%<\AcSm Sheet.Number \f "%tc3">%
In this example (see attachement) Status is Work in Progress so it should show only doubleU (W) and it does - see the lower red circle.
This is the part: %<\AcDiesel $(substr,%<\AcVar CustomDP.Status>%,1,1)>%
But the problems is when status changes the diesel expression is not evaluted anymore, so "project number/ drawingnumber"in titleblock is still showing "W", In fact when i look in the field i see the text "Work in Progress"as text. So only the first time a drawing is checked in into the Vault the diesel expression is evaluated and replacing itself to text.
Ofcourse i would not, and the diesel expression stays and evaluated every Regen or whatever is responsable for evaluating this.
I am native dutch, so i hope my english is clear enough.
Someone any idea?
Klaas
Hi Klaas,
This seems like an issue in AutoCAD. If it is please post the question in the AutoCAD customization forum.
http://forums.autodesk.com/t5/autocad-customization/ct-p/AutoCADTopic1
If it is a Vault API issue please provide more details.
Wayne
