Vault Customization
Share your knowledge, ask questions, and explore popular Vault API, Data Standard, and VBA topics related to programming, creating add-ins, or working with the Vault API.
DetailPaneTab selection set
3 REPLIES 3
jsjk
623 Views, 3 Replies
I want to have a DetailPaneTab that shows information on all of the currently selected files/folders.  The SelectionChanged event only provides a single iSelection object, not a collection.  The only place I see a collection of selection objects is in CommandItemEventArgs.  However, this is only available within a command.
Is there anyway I can get all of the currently selected objects when populating my custom Tab?
The only idea I have right now is to use a new command instead of a custom tab.  The command would have access to the selected objects.  I would have to display the information in a separate dialog box instead of the custom tab.
3 REPLIES 3
Redmond.D
in reply to: jsjk
This is just the way tab views work.  They only apply to a single object.  If you try to multi-select, the last selected object is what is shown in the tab.  The default tabs work this way too.
Currently the only way you can get multi-select information is through a custom command.
Doug Redmond
Software Engineer
Autodesk, Inc.
anaumann
in reply to: Redmond.D
Hi Doug,
is this still that behavior? Are there planed any changes to this? It would be great to get the possibility to work with selectionsets within detailtabs in a future release.
With kind regards
André Naumann
Redmond.D
in reply to: jsjk
Sorry the behavior has not changed and there are no planned changes.
Doug Redmond
Software Engineer
Autodesk, Inc.
