Vault Customization
Share your knowledge, ask questions, and explore popular Vault API, Data Standard, and VBA topics related to programming, creating add-ins, or working with the Vault API.
Data Standard : Read in Adsklib definition
2 REPLIES 2
fsanchou
299 Views, 2 Replies
I would like to be able to choose the part’s material using either the name, comment or keyword.
I know how to link comboBox each other.
My question is: How to read additional fields of material and add these fields in combo box?
2 REPLIES 2
marco.mirandola
in reply to: fsanchou
Hi, with Data Standard at the moment only the material property is exposed. There is a property called Material. If you set the Value of the Material (Prop[Material].Value="Aluminium"), then the material in Inventor will be set accordingly. If you bind the ItemsSource of a combobox to Prop[Material].ListValues then you get the combobox populated with the materials available in Inventor. Here is a sample http://blog.coolorange.com/2014/02/07/data-standard-how-much-wpf-do-you-need-to-know/
However, there are no more information on material.
i hope this helps.
ciao
marco
coolOrange
www.coolorange.com
fsanchou
in reply to: marco.mirandola
Marco,
I am already able to change the material from a combo box as you describe in the link.
I want to change but using either name or description
Thanks you for your reply.
