Is it possible to run an iLogic rule by clicking a button in Data Standard?
Marco,
I use a rule that retrieves the size of part informations and written in iproperties. I want to launch rule with this button and be able to modify values in DS.
I don't want to automate this action with a trigger event.
I also would like to have the abillity to acces ilogic (extern) or the Inventor API.
The problem which i have is that we save the drawings on the same locations as the ipt or iam.
And with Data standard i can't get the referenced file. I haven't jet found an easy workaround for this.
Both requirements of this thread are already or can get solved:
1) get file location and properties of drawing's model: we just are rolling out a "Quickstart" environment, fully configured Vault 2015 R2 environment, capable doing this. Compare the screenshot below: project selection is for display only, as the path is retrieved from models location. The same for metadata; however the user is allowed to override title & description for the drawing.
2) in the same way I did the communication to Inventor for 1), I should be able to use iLogic rules to evaluate values and return to the current dialog.
How to get the stuff? Let me know your reseller's name and I reach out to the colleagues there.
Markus
Solutions Engineer PDM, Autodesk Central Europe
Can i call a I-Locic rule from Data Standard in 2017 ??
Regards Gerd
