Vault Customization
Share your knowledge, ask questions, and explore popular Vault API, Data Standard, and VBA topics related to programming, creating add-ins, or working with the Vault API.
Current And changed state names
8 REPLIES 8
Message 1 of 9
amitnkukanur
539 Views, 8 Replies
i am trying to figure out how to get the current state name and changed state name..
i used UpdateFileLifecycleStateEvents_Pre and Post but none of them are triggering events to fetch the label names.
Any body has idea
Senior Software Engineer
8 REPLIES 8
Message 2 of 9
Redmond.D
in reply to: amitnkukanur
Can you clarify the problem.
Are you saying that the Pre and Post events are not firing?  Or are you saying that they are fireing but you don't know how to look up the state names from the EventArgs?
Doug Redmond
Software Engineer
Autodesk, Inc.
Message 3 of 9
amitnkukanur
Thanks Doug Redmond for reply, the issue is in Pre and Post events are not at all firing and if they fire how you fetch the state names. Currently i am able to fetch the previous State name, but when the state name is changed to new one, i am unable to fetch the name of state
Message 4 of 9
Redmond.D
So, you have two problems...
Problem 1: Events not firing
Make sure that your app is loading.  Put a breakpoint in the OnLoad method to verify.  See this article for more information on troubleshooting load errors.
Problem 2:  Figuring out the state name
The FROM information can be found on the File objects.  GetLatestFileByMasterId and GetFilesByMasterId are the functions to use.
The TO information can be found by calling LifeCycleService.GetLifeCycleStatesByIds
Doug Redmond
Software Engineer
Autodesk, Inc.
Message 5 of 9
amitnkukanur
In which module i would file LifeCycleService
Message 6 of 9
Redmond.D
Sorry, that's a new service in Vault 2013.  If you are using Vault 2012, the function is in DocumentServiceExtensions.
Doug Redmond
Software Engineer
Autodesk, Inc.
Message 7 of 9
amitnkukanur
Hi Doug, the GetLifeCycleStatesByIds still points to previous state name, when i change the life cycle and click OK, the GetLifeCycleStatesByIds still refer to previous state.
Message 8 of 9
amitnkukanur
I got it myseld from the current state ID
Message 9 of 9
in reply to: Redmond.D
I have a similar problem the Post event it fires, but the Pre event dont fires, I only will know the last lyfecyclestate before the user has change it, for example the user makes a change from "A state to B state", in the Post event I know that the new state is the "B state"  but I will know the A state, the problem is that the Pre event dont fire.
  public void OnStartup(IApplication application)
            m_explorerApplication = application;
            DocumentServiceExtensions.UpdateFileLifecycleStateEvents.Pre += new EventHandler<UpdateFileLifeCycleStateCommandEventArgs>(UpdateFileLifecycleStateEvents_Pre);
            DocumentServiceExtensions.UpdateFileLifecycleStateEvents.Post +=
             new EventHandler<UpdateFileLifeCycleStateCommandEventArgs>(UpdateFileLifecycleStateEvents_Post);
 void UpdateFileLifecycleStateEvents_Post(object sender, UpdateFileLifeCycleStateCommandEventArgs e)
//My logic, this event is fired and works.
void UpdateFileLifecycleStateEvents_Pre(object sender, UpdateFileLifeCycleStateCommandEventArgs e)
            // this event is never fired. dont works....
 Why I have this problem?
