I have task. I need to get some report of folders and get information how much each first level folder have file. If the in folder is no files then I must get zero.
I need to get report and see what situation I have in each folder.
Best regards
Darius
Could you please look at the VaultList sample from the Vault SDK samples collection.
It illustrates browsing folders and files in the Vault.
Default location: C:\Program Files (x86)\Autodesk\Autodesk Vault 20XX SDK\VS10\CSharp\VaultList
Sorry but It is not possible to create reports (RDLC files) using Vault API.
You may use Autodesk Report Template Utility described here:
