Vault Customization
Share your knowledge, ask questions, and explore popular Vault API, Data Standard, and VBA topics related to programming, creating add-ins, or working with the Vault API.
Copy Design Event
2 REPLIES 2
xavier_dumont1
717 Views, 2 Replies
Copy Design Event
Hi all,
I want to get a list of all new files created by a Copy-Design command.
Then I need to create a Vault add-in who can hook CommandEnd Event and if the command is CopyDesign, get the list on new file.
But I don't find any list of file.ids when this command event fire.
I found this link, but don't understand how can I do that because I think it's two kind of add-in (IWebServiceExtension + IExplorerExtension).
http://justonesandzeros.typepad.com/blog/2011/09/vault-explorer-command-events.html
Sorry, I'm not a developper, maybe the solution is very easy but I don't find a way to do that.
Thanks in advance and hav a nice day.
2 REPLIES 2
Daniel.Du
in reply to: xavier_dumont1
Yes, as Doug said in the blog post, it can be a combination of explorer command events and web service command events, I did a quick demo as below, without error checking, just for your reference:
    public class Class1 : IExplorerExtension
        #region IExplorerExtenion implemenation
//some methods are ommited
        public void OnStartup(IApplication application)
            application.CommandBegin += application_CommandBegin;
            application.CommandEnd += application_CommandEnd;
        void application_CommandEnd(object sender, CommandEndEventArgs e)
            if (String.Compare(e.CommandId,"CopyDesign") == 0)
                string filenames = WebServiceEventHandler.fileNames.ToString();
                MessageBox.Show(filenames);
        TextDialog m_commandBox;
        void application_CommandBegin(object sender, CommandBeginEventArgs e)
            if (String.Compare(e.CommandId, "CopyDesign") == 0)
                WebServiceEventHandler.fileNames.Clear();
        #endregion
    class WebServiceEventHandler : IWebServiceExtension
        public static StringBuilder fileNames = new StringBuilder();
        public void OnLoad()
            DocumentService.AddFileEvents.Post += AddFileEvents_Post;
        void AddFileEvents_Post(object sender, AddFileCommandEventArgs e)
            fileNames.Append(e.FileName + "\n");
and here is vcet.config file:
<?xml version="1.0" encoding="utf-8" ?>
<configuration>
  <connectivity.ExtensionSettings3>
    <extension
      interface="Autodesk.Connectivity.Explorer.Extensibility.IExplorerExtension, Autodesk.Connectivity.Explorer.Extensibility, Version=18.0.0.0, Culture=neutral, PublicKeyToken=aa20f34aedd220e1"
      type="ExplorerEventSample.Class1, ExplorerEventSample">
    </extension>
    <extension
        interface="Autodesk.Connectivity.WebServices.IWebServiceExtension, Autodesk.Connectivity.WebServices, Version=18.0.0.0, Culture=neutral, PublicKeyToken=aa20f34aedd220e1"
        type="ExplorerEventSample.WebServiceEventHandler, ExplorerEventSample">
    </extension>
  </connectivity.ExtensionSettings3>
</configuration>
Daniel Du
Developer Technical Services
Autodesk Developer Network
It's perfect. I found now where I'm wrong regarding the vcet.config file.
Thanks a lot.
