Vault Customization
Vault Customization
16 Kudos
Post 1 of 3
Conversion of File to ByteArray
869 Views, 2 Replies
01-11-2013 04:19 AM
I know this is a silly question, but i am stuck up with conversion of file to ByteArray. Can some body please suggest me how to convert a file to ByteArray.
My Problem is i have to add a file to Vault 2013 using C#. If a solution link is provided that would be help full
Rgds
Amit
You are not the first to get confused between byte[] and ByteArray.  The VaultFileBrowser sample in the SDK has an example.
The basic steps are:
  1. Read in the local file as a byte[].  You can do this using a System.IO.FileStream or calling System.IO.File.ReadAllBytes.
  2. Create a new ByteArray object and set the 3 properties.  For simplicity, I suggest not using compression.
  3. Pass in the ByteArray object to the Add or CheckIn function.
Employee
270 Kudos
Post 2 of 3
Re: Conversion of File to ByteArray
01-11-2013 04:54 AM in reply to: amitk_189
Doug Redmond
Software Engineer
http://justonesandzeros.typepad.com/
16 Kudos
Post 3 of 3
01-12-2013 07:57 AM in reply to: Redmond.D
Perfect, thanks for solution. It worked.
