Vault Customization
Share your knowledge, ask questions, and explore popular Vault API, Data Standard, and VBA topics related to programming, creating add-ins, or working with the Vault API.
ConnectionManager.GetExistingConnection() is always returning null
1 REPLY 1
rajeshkorada
524 Views, 1 Reply
Hi experts,
              I am trying to use the following API in Vault 2014
Autodesk.DataManagement.Client.Framework.Vault.Library.ConnectionManager.GetExistingConnection() , this API is always returning NULL.
I have tried to login multiple time with same user id , password, server , vault and authentication data, still i get NULL
Has any one used this API, please  let me know if any pre-requisties need to followed before calling the API.
Regards
Rajs
Thanks and Regards
Rajesh Korada
1 REPLY 1
smithmat
in reply to: rajeshkorada
Here is a sample usages of the API showing it behaving correctly:
var connectionManager = Autodesk.DataManagement.Client.Framework.Vault.Library.ConnectionManager;
var loginResult = connectionManager.LogIn("localhost""Vault""Administrator"""AuthenticationFlags.Standard, null /* progressCallback */);
var connection = loginResult.Connection;
var existingConnection = connectionManager.GetExistingConnection("localhost""Vault""Administrator"""AuthenticationFlags.Standard);
Console.WriteLine("Connection: {0}",  connection.Ticket);
Console.WriteLine("Existing Connection: {0}", existingConnection.Ticket);
connectionManager.LogOut(connection);
connectionManager.LogOut(existingConnection);
Output:
Connection: c88aead3-ffb6-4ae3-a8b9-c964ad179cab
Existing Connection: c88aead3-ffb6-4ae3-a8b9-c964ad179cab
In order for GetExistingConnection to return a connection, there must already exist an identical signed in connection (and it had have signed in using the ConnectionManager.
Hope that helps,
- Matt
