Vault Customization
Share your knowledge, ask questions, and explore popular Vault API, Data Standard, and VBA topics related to programming, creating add-ins, or working with the Vault API.
Checkout
2 REPLIES 2
amitnkukanur
373 Views, 2 Replies
Checkout
Am stuck up in file check out event, actually slightly modified my code so that the current proccess is FileCheckOut-Update-FileCheckin.
I used
 mgr.DocumentService.CheckoutFile(folder.Id,file.Id,CheckoutFileOptions.Master,"DUMMY","D:\\Temp\\Test\\","",DownloadOptions.Download,false,
Issue: what should i specify the last option, that is Out ByteArray FileContents and will this option checks out a file
Senior Software Engineer
2 REPLIES 2
Redmond.D
in reply to: amitnkukanur
You create a new ByteArray variable and pass that in.  For C# you use the 'out' keyword.
The CheckinFile page has some exampe code.
Doug Redmond
Software Engineer
Autodesk, Inc.
amitnkukanur
Ok Doug, I will work on It. Thanks for Information.
Thanks and Regards
Amit
