Vault Customization
Share your knowledge, ask questions, and explore popular Vault API, Data Standard, and VBA topics related to programming, creating add-ins, or working with the Vault API.
CheckinFile provides error 1022 (SelfDependency)
1 REPLY 1
ewcv
923 Views, 1 Reply
my procedure of updating an UPD of a file works in the most cases,
but in some cases CheckinFile provides error 1022 (SelfDependency)
"Error retuned from Vault Server: SelfDependency   System.Web.Services.Protocols.SoapException: 1022 ..."
I don't know why, has anone an idea?
my code:
System.Byte[] fileContents;
// long m_nIdDoc is the Id of my file and m_nIdDocMaster is the associated Masterid
AWeb.Folder[] folders = m_ServiceManager.DocumentService.GetFoldersByFileMasterId(m_nIdDocMaster);
if (folders != null && folders.Length > 0)
    string sDirectory = Environment.CurrentDirectory;
    bool bEnv = m_ServiceManager.DocumentService.GetEnforceWorkingFolder();
    if (bEnv == true)
        sDirectory = m_ServiceManager.DocumentService.GetRequiredWorkingFolderLocation();
    AWeb.File fileM = m_ServiceManager.DocumentService.CheckoutFile(folders[0].Id, m_nIdDoc, AWeb.CheckoutFileOptions.Master, Environment.MachineName, sDirectory, "comment", false, false, out fileContents);
    try
        m_ServiceManager.DocumentService.UpdateFileProperties(new long[] { m_nIdDocMaster }, new long[] { 104 }, new object[] { "my comment" });
    catch (Exception ex)
        sMessage = CommonFunctions.getErrorAndRestrictionCodesString(ex);
        try
            m_ServiceManager.DocumentService.UndoCheckoutFile(m_nIdDocMaster, false, out fileContents);
        catch {}
    try
        AWeb.FileAssocParam[] assocsParam = getFileAssocParam(m_nIdDocMaster, m_ServiceManager, ref sMessage);
        m_ServiceManager.DocumentService.CheckinFile(m_nIdDocMaster, "my comment", false, DateTime.Now, assocsParam, null, true, fileM.Name, fileM.FileClass, fileM.Hidden, null);
    catch (Exception exCheckin)
        sMessage = CommonFunctions.getErrorAndRestrictionCodesString(exCheckin);
1 REPLY 1
Redmond.D
in reply to: ewcv
Self dependency probably means you are trying to set file X as a dependency or attachment of file X, which is logically impossible.
Take a closer look at assocsParam to make sure the association points to a different file than the one you are updating.
Doug Redmond
Software Engineer
