Vault Customization
Share your knowledge, ask questions, and explore popular Vault API, Data Standard, and VBA topics related to programming, creating add-ins, or working with the Vault API.
Check-in failed: file at xxx does not exist. Parameter name: filePath
1 REPLY 1
wesbird
554 Views, 1 Reply
  I move the AddOrUpdateFile from Doug's Thunderdome example. Now I like to checkin a pdf from a folder which is not working folder.
  here is the error message:
Check-in failed: file at xxxx does not exist.
Here is the code:
        public ACW.File AddOrUpdateFile(string localPath,
            string fileName, ACW.Folder vaultFolder, string comment = "")
            Console.WriteLine("AddOrUpdateFile---" + System.IO.File.Exists(Path.Combine(localPath, fileName)).ToString()); // this return true
            string vaultPath = vaultFolder.FullName + "/" + fileName;
            ACW.File[] result = _docSvc.FindLatestFilesByPaths(
                vaultPath.ToSingleArray());
            ACW.File retVal = null;
            if (result == null || result.Length == 0 || result[0].Id < 0)
                VDFE.Folder vdfFolder = new VDFE.Folder(
                    m_cache.Conn, vaultFolder);
                // using a stream so that we can set a different file name
                using (FileStream stream = new FileStream(localPath, FileMode.Open, FileAccess.Read))
                    VDFE.FileIteration newFile = m_cache.Conn.FileManager.AddFile(
                        vdfFolder, fileName, comment,
                        System.IO.File.GetLastWriteTime(localPath), null, null,
                        FileClassification.None, false, stream); // <-<- here is the error popup
                    retVal = newFile;
            else
                VDFE.FileIteration vdfFile = new VDFE.FileIteration(m_cache.Conn, result[0]);
                AcquireFilesSettings settings = new AcquireFilesSettings(m_cache.Conn);
                settings.AddEntityToAcquire(vdfFile);
                settings.DefaultAcquisitionOption = AcquireFilesSettings.AcquisitionOption.Checkout;
                AcquireFilesResults results = m_cache.Conn.FileManager.AcquireFiles(settings);
                if (results.FileResults.First().Exception != null)
                    throw results.FileResults.First().Exception;
                vdfFile = results.FileResults.First().File;
                VDF.Currency.FilePathAbsolute fpa = localPath.ToVDFPath();
                vdfFile = m_cache.Conn.FileManager.CheckinFile(vdfFile, comment, false,
                    null, null, false, null, FileClassification.None, false, fpa);
                retVal = vdfFile;
            return retVal;
  I checked and checked again, file is in localpath. What could be the mistake?
Thank you very much
Wes
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
1 REPLY 1
wayne.brill
in reply to: wesbird
Hello Wes,
The subject of this case says "Check-in failed, but in the code there is a comment that error is occurring on AddFile. I am not recreating an error using AddFile().
                    VDFE.FileIteration newFile = m_conn.FileManager.AddFile(
                        ACW.FileClassification.None, false, stream); // <-<- here is the error popup
                    retVal = newFile;
Could it be the error is happening on this line?
vdfFile = m_conn.FileManager.CheckinFile(vdfFile, comment, false,
null, null, false, null, ACW.FileClassification.None, false, fpa);
I am able to recreate an error like this if fpa is a path where the file that is being checked in does not exist.
Wayne
Wayne Brill
Developer Technical Services
Autodesk Developer Network
