Vault Customization
Share your knowledge, ask questions, and explore popular Vault API, Data Standard, and VBA topics related to programming, creating add-ins, or working with the Vault API.
Change file state
1 REPLY 1
erik.martinsson
303 Views, 1 Reply
Change file state
Does anyone know if there's a way to add more comments to the CommArray for a certain state? I would like to be able to keep an existing comment when moving from one state to another. I'm listening to the pre/post-events of DocumentServiceExtensions.UpdateFileLifecycleStateEvents, extracting the "currentComment" in PRE, and trying to write it to the new version of the file in POST:
private string currentComment = "";
    void UpdateFileLifecycleStateEvents_Pre(object sender, UpdateFileLifeCycleStateCommandEventArgs e)
      VaultServiceManager _vltMgr = CommonMain.Instance.VaultServiceManager;
      File[] files = _vltMgr.WebServiceManager.DocumentService.GetLatestFilesByMasterIds(e.FileMasterIds);
      try
        currentComment = files[0].Comm;
      catch (Exception) { }
void UpdateFileLifecycleStateEvents_Post(object sender, UpdateFileLifeCycleStateCommandEventArgs e)
      try
        files[0].Comm = currentComment;
The new state always has it's own predefined comment from the dropdown in the "change state dialog". The e.Comment is "readonly" and not possible to change...And since - is there a way to modify this dialog before it shows?
1 REPLY 1
minkd
in reply to: erik.martinsson
The comments are part of the lifecycle and are fully customizable.  You don't need to write code to customize them.
In Vault Explorer, go to Tools >> Administration >> Vault Settings >> Behaviors tab >> "Lifecycles ..." button >> choose lifecycle and press Edit to bring up the dialog (see attached screenshot). Each state has a list of comments (shown in the "Comments" tab on the right).
-Dave
Dave Mink
Fusion Lifecycle
Autodesk, Inc.
