Vault Customization
Share your knowledge, ask questions, and explore popular Vault API, Data Standard, and VBA topics related to programming, creating add-ins, or working with the Vault API.
category rules
1 REPLY 1
jacoj
376 Views, 1 Reply
category rules
hi
I want to be able to set my vault to change categories from internal documentation to external documentation ,
so as I reached revision G ( released for production) , can I set up a rule in vault then to change the Category from internal docs to external docs automaticly, and then use revison scheme numerical then instead of alfabetical, and also change filecyle assigned to external category, and a differint lifecycle?
1 REPLY 1
Marat.Mirgaleev
in reply to: jacoj
   I see that you are asking the same question here:
      http://forums.autodesk.com/t5/Autodesk-Vault/rule-based-category-and-lifecycle-change/td-p/3770476
and that thread is much more active...
Marat Mirgaleev
Developer Technical Services
Autodesk Developer Network
