Vault Customization
Vault Customization
Active Member
0 Kudos
Post 1 of 4
calling a drawing from the vault within VB.NET
259 Views, 3 Replies
09-28-2012 01:20 PM
What is the vault name or procedure for getting an autoCAD drawing from the vault
example from the c drive I use:
g_acadDoc = m_AcadApp.Documents.Open("C:\VAULT_WIP\DWG\L324532.dwg")
What would you use instead of C:\
Employee
270 Kudos
Post 2 of 4
Re: calling a drawing from the vault within VB.NET
10-01-2012 05:51 AM in reply to: dbvetter01
You call DownloadFile, which gives you a byte array.  You can then save the array to any location on disk that you want.  See the VaultFileBrowser sample in the SDK for an example of a download.
Doug Redmond
Software Engineer
http://justonesandzeros.typepad.com/
Active Member
0 Kudos
Post 3 of 4
10-01-2012 01:26 PM in reply to: dbvetter01
Isn't there a way to map the database as a drive letter?  or server path?  It would be so much easier for programmers.
In other EMDS you can map the main vault as a drive letter i.e V:\
Employee
270 Kudos
Post 4 of 4
10-03-2012 04:52 AM in reply to: dbvetter01
Autodesk.Connectivity.Explorer.ExtensibilityTools.dll has some utilities to help with this.
There is a DownloadFile function which will download to the user's working folder location.
Doug Redmond
Software Engineer
