Is there any dialog from SDK, similar to the common FolderBrowserDialog in c# corresponding to Vault and creating folder in Vault?
See attached picture.
There is Autodesk.DataManagement.Client.Framework.Vault.Forms.Library.SelectEntity
That should allow you a way to select a folder, but I don't believe there is a way to enable creating a folder.
Hi, I found this when exploring the SelectEntitySettings, I try to use it, but no "create folder" button is displayed. How is this used then?
See attachment again 🙂
I found it, in the upper right corner, so it do seem possible.
However, how do I set the filter to only display folders in the browser dialog...cannot find the appropriate setting or filter.
Thanks..
Perhaps setting the SelectEntitySettings.EntityFilters to only contain a custom EntityFilter that shows only folders?
