Solved by Redmond.D. Go to Solution.
Saying that your app "will not work" doesn't give me much to go on. Can you provide more details on the problem? Error messages, screenshots, the line of code that fails, etc.
Thanks for the interest, Doug.
I have attached the screenshot of the error, although it is pretty nondescript.
When launching the executable, I first setup a WinAuthSvc using default credentials. Next I do a simple check for userid. I am not even making it to the check for userid. I launch the app from a remote server, and can do so on any of our machines where we have previously loaded Vault. Even if we unistall Vault, the app will still launch. However, on machines connected to the same network without a previous installation of the vault client, we cannot launch the tool. Any insights or thoughts would be greatly appreciated. Perhaps I am not copying down a necessary .dll?
Thanks again,
Tim
code snippit below:
staticvoidMain()
Application.EnableVisualStyles();
Application.SetCompatibleTextRenderingDefault(false);
Services my_svc = Services.getServices(); // simply setting up my services template
try
Services.getWAService(); // see below
publicstaticWinAuthServicegetWAService()
Servicessvc = getServices();
if (svc.WAsvc == null)
WinAuthService my_wasvc = newWinAuthService();
my_wasvc.Url ="http://vault2011/AutodeskDM/Services/WinAuth/WinAuthService.asmx";
my_wasvc.UseDefaultCredentials = true;
my_wasvc.SecurityHeaderValue =
new Autodesk.Connectivity.WebServices.WinAuthSvc.SecurityHeader();
my_wasvc.SignIn(chosenVault);
svc.WAsvc = my_wasvc;
returnsvc.WAsvc;
I noticed you have a try block in your Main, which is good. It might be a good idea to log any errors in your catch block if you are not doing so already.
Anyway, you are probably right that something is missing. Microsoft Web Services (WSE) 3.0 is my best guess. At the DLL level this is the Microsoft.Web.Services3 assembly. You can download WSE from the Microsoft web site.
Another thing to check is the .NET version. If your app is .NET 4.0, then the 4.0 framework needs to be installed.
I believe that the 2011 version of Autodesk.Connectivity.Explorer.Extensibility.dll is built on .NET 3.5.
