Vault Customization
Share your knowledge, ask questions, and explore popular Vault API, Data Standard, and VBA topics related to programming, creating add-ins, or working with the Vault API.
Adding custom menu to Bill of Materials tab of Item Master
2 REPLIES 2
603 Views, 2 Replies
I would like to know if it is possible to add a context menu item to the BOM tab within Item explorer. See image.
I experimented with the HelloWorld example in the Vault 2013 SDK. I modified it such that it displays "Hello Item" in the context menu when an item is selected in the top pane.
If I switch to the Bill of Materials tab and select an item, I do not see the Hello Item menu.
If I switch to Where Used to and select an item, I can see it.
Any ideas?
2 REPLIES 2
Marat.Mirgaleev
Unfortunately, adding custom commands to BOM is not supported.
You should be using an assignment like this (copied from the HelloWorld sample):
      NavigationTypes = new SelectionTypeId[] { SelectionTypeId.File, SelectionTypeId.FileVersion }
Which members of the SelectionTypeId class are you using?
Marat Mirgaleev
Developer Technical Services
Autodesk Developer Network
