I created a new category via CategoryService.AddCategory and chose LimeGreen as the color. This appeared to work fine, I ran through some in code and set the category. I launched Vault explorer and saw the categories were set properly, even showing my color. However, I loaded the vault settings and went to the configure categories dialog to change category behaviors, when I started getting error messages. I was able to see the lime green color in this dialog When I choose edit I get a crash dialog as if Vault crashed, but Vault stays open. When I close the error report dialog I get a Vault error saying "The given key was not present in the dictionary". I clicked ok on it and tried again to edit and it continued to happen. I closed Vault explorer and reloaded it and went back to the configure categories dialog. I noticed my lime green color no longer shows up here. If I try to copy the category I get the same dictionary error. I can see the color on my files and I can see it in the dialog to change the category. I deleted the category and called addCategory again this time using a color from GetAllCategoryColors() and it all worked fine, I could edit the category.
So I am wondering if this is a known issue and if it would be possible to have it allow any color instead of one from a set of 26.
Solved by Redmond.D. Go to Solution.
No, I was not aware of this issue. Thanks for letting me know. I'll log a defect.
The workaround for now is to just use one of the pre-defined colors.
