Hi All,
Does somebody know if it's possible to add information to a link through the Vault API? If so, how should this be done?
What I would like to do is this:
I create two new item of a custom object. Then I copy a folder and paste this as a link to the first new custom entity. Then I copy the same folder and paste this to the other custom entity. Know I would like to add information to these two links to be able to track certain things..
Pim
Solved by Redmond.D. Go to Solution.
The AddLink function has a 'data' parameter that lets you set whatever metadata you want on the link. You can read the metadata with the GetDataOnLinks() function.
