I'm having trouble getting a file from folder. I'm using some code from an example I found. But tried to modify it to look in a specific folder.
I can't seem to get the folder id.
Sub would be called something like this: DownloadFile("C:/VaultWork/_Designs/Folder1/Filename.ipt")
it returns this error message:
A first chance exception of type 'System.Web.Services.Protocols.SoapException' occurred in Autodesk.Connectivity.WebServices.dll
Private Sub DownloadFile(filename As String) Dim results As VDF.Vault.Results.LogInResult = VDF.Vault.Library.ConnectionManager.LogIn("rusgrveng1", _ "gveng", _ "username", _ "password", _ VDF.Vault.Currency.Connections.AuthenticationFlags.Standard, Nothing) If Not results.Success Then Return 'exit sub End If Dim connection As VDF.Vault.Currency.Connections.Connection = Nothing connection = results.Connection Try Dim oFileIteration As VDF.Vault.Currency.Entities.FileIteration = Nothing Try 'Get the file iteration oFileIteration = GetFileIteration(filename, connection) Catch ex As Exception Debug.WriteLine("Could not get file iteration") End Try If oFileIteration IsNot Nothing Then 'get settings Dim oSettings As VDF.Vault.Settings.AcquireFilesSettings = New VDF.Vault.Settings.AcquireFilesSettings(connection) oSettings.DefaultAcquisitionOption = VDF.Vault.Settings.AcquireFilesSettings.AcquisitionOption.Download oSettings.AddEntityToAcquire(oFileIteration) 'do the download connection.FileManager.AcquireFiles(oSettings) End If Catch ex As Exception Debug.WriteLine("Could not download file") Finally VDF.Vault.Library.ConnectionManager.LogOut(connection) End Try End Sub Private Function GetFileIteration(nameOfFile As String, connection As VDF.Vault.Currency.Connections.Connection) _ As VDF.Vault.Currency.Entities.FileIteration Dim conditions As ACW.SrchCond() ReDim conditions(0) Dim lCode As Long = 1 Dim Defs As ACW.PropDef() = connection.WebServiceManager.PropertyService.GetPropertyDefinitionsByEntityClassId("FILE") Dim Prop As ACW.PropDef = Nothing For Each def As ACW.PropDef In Defs If def.DispName = "File Name" Then Prop = def End If Next def 'store path in new string Dim pathname As String = nameOfFile.Substring(0, nameOfFile.LastIndexOf("\") + 1) Debug.WriteLine(pathname) 'remove path from nameOfFile Dim filename As String = nameOfFile.Substring(nameOfFile.LastIndexOf("\") + 1, nameOfFile.Length - pathname.length) Debug.WriteLine(filename) 'convert local path string to vault format Dim VaultPath As String = pathname.Substring(0, pathname.Length - 1) VaultPath = VaultPath.Replace("C:\VaultWork\", "$/") 'flip the slashes VaultPath = VaultPath.Replace("\", "/") Debug.WriteLine(VaultPath) Dim DocService As Autodesk.Connectivity.WebServices.DocumentService Dim myFolder As Folder Dim myFolderId As Long Try DocService = New Autodesk.Connectivity.WebServices.DocumentService() myFolder = DocService.GetFolderByPath(VaultPath) myFolderId = myFolder.Id Catch ex As Exception Debug.WriteLine(ex.Message) End Try Debug.WriteLine(myFolderId) Dim myFolderIds(0) As Long myFolderIds(0) = myFolderId Dim searchCondition As ACW.SrchCond = New ACW.SrchCond() searchCondition.PropDefId = Prop.Id searchCondition.PropTyp = ACW.PropertySearchType.SingleProperty searchCondition.SrchOper = lCode 'searchCondition.SrchTxt = nameOfFile 'nameofFile includes path searchCondition.SrchTxt = filename 'filename does not include path conditions(0) = searchCondition 'search for files Dim FileList As List(Of Autodesk.Connectivity.WebServices.File) = New List(Of Autodesk.Connectivity.WebServices.File)() Dim sBookmark As String = String.Empty Dim Status As ACW.SrchStatus = Nothing While (Status Is Nothing OrElse FileList.Count < Status.TotalHits) Dim files As Autodesk.Connectivity.WebServices.File() = connection.WebServiceManager.DocumentService. _ FindFilesBySearchConditions(conditions, Nothing, myFolderIds, True, True, sBookmark, Status) If (Not files Is Nothing) Then FileList.AddRange(files) End If End While Dim oFileIteration As VDF.Vault.Currency.Entities.FileIteration = New VDF.Vault.Currency.Entities.FileIteration(connection, FileList(0)) Return oFileIteration End Function
Solved by Redmond.D. Go to Solution.
Here is how I suggest writing the function...
Once you have the Vault path of the file (ex. $/_Designs/Folder1/Filename.ipt), call connection.WebServiceManager.DocumentService.FindLatestFilesByPaths to get the File objects. It's easier than using search conditions.
Next, create a new FileIteration object for that File and use AcquireFiles to perform the dowload.
Also, next time you get a SoapException, you can use Autodesk.DataManagement.Client.Framework.Library.ExceptionParser to extract more details about what went wrong.
Doug, Thank you for the reply. I have revised my code, but I'm still missing something. Please review and advise.
Private Sub DownloadFile(fullfilename As String) Dim results As VDF.Vault.Results.LogInResult = VDF.Vault.Library.ConnectionManager.LogIn("rusgrveng1", _ "gveng", _ "username", _ "password", _ VDF.Vault.Currency.Connections.AuthenticationFlags.Standard, Nothing) If Not results.Success Then Return 'exit sub End If Dim connection As VDF.Vault.Currency.Connections.Connection = Nothing connection = results.Connection Try Dim oFileIteration As VDF.Vault.Currency.Entities.FileIteration = Nothing Try 'convert local path string to vault format Dim VaultPath As String = fullfilename VaultPath = VaultPath.Replace("C:\VaultWork\", "$/") 'flip the slashes VaultPath = VaultPath.Replace("\", "/") Dim VaultPaths() As String = New String() {VaultPath} Dim DocService As ACW.DocumentService DocService = New ACW.DocumentService() Dim files As ACW.File() files = DocService.FindLatestFilesByPaths(VaultPaths) Dim file As ACW.File file = files(0) oFileIteration = New VDF.Vault.Currency.Entities.FileIteration(connection, file) Catch ex As Exception Debug.WriteLine("Could not get file iteration" & ex.Message) End Try If oFileIteration IsNot Nothing Then 'get settings Dim oSettings As VDF.Vault.Settings.AcquireFilesSettings = New VDF.Vault.Settings.AcquireFilesSettings(connection) oSettings.DefaultAcquisitionOption = VDF.Vault.Settings.AcquireFilesSettings.AcquisitionOption.Download oSettings.AddEntityToAcquire(oFileIteration) 'do the download connection.FileManager.AcquireFiles(oSettings) End If Catch ex As Exception Debug.WriteLine("Could not download file") Finally VDF.Vault.Library.ConnectionManager.LogOut(connection) End Try End Sub
I saw in another post where you advised the user to set the security header for the document service object and copy the userid and ticket values from security service headervalue to all the other services. Do I need to do that? If yes, please elaborate.
You shouldn't be creating new service objects. They are already built and managed by the Connection object. So you call connection.WebServiceManager.DocumentService whenever you want to use the Document Service.
