Is it possible to acquire several versions of the same file in one call to FileManager.AcquireFiles?
I'm using a different path for each version by using the third argument of AddFileToAcquire:
settings.AddFileToAcquire(fileVer11, AcquireFilesSettings.AcquisitionOption.Download, path11); settings.AddFileToAcquire(fileVer8, AcquireFilesSettings.AcquisitionOption.Download, path8); settings.AddFileToAcquire(fileVer5, AcquireFilesSettings.AcquisitionOption.Download, path5);
With that, I've only one file (path5) and if I look to the results of AcquireFiles, it's the 11th version that is downloaded.
Solved by smithmat. Go to Solution.
No, it is not possible. When there are multiple versions of the same file, the latest file is chosen. Unfortunately, you'll have to do mutliple AcquireFiles to get different versions.
