To whom it may concern,
Is it possible to enable/disable user accounts via the api? If so, how?
Thank you,
Eric
Solved by Redmond.D. Go to Solution.
Yes, AdminService.UpdateUserInfo is the function you use.
You can only use it if you are logged in as an administrator.
