i use Vault Data Standard 2015 R2 with the new Numbering Schemes support.
But now i have a new Number for all files also for .idw and .ipn.
How can i disable the Number generator for .idw and .ipn files?
Thanks for your help.
Hi Marcel,
Data Standard currently doesn't support the options for disabling the New Numbering Schemes out of the box for the .ipn and .dwg files.
Having said that, you can however, customize (which the Data Standard is known for) to disable the numbering schemes for the said files. In order to do that, you have to find the Default.ps1 file under this location 'C:\ProgramData\Autodesk\Vault 2015 R2\Extensions\DataStandard\CAD\addins'.
In this powershell script file, there is a function 'GetNumSchms' which will return the active numbering schemes for every file type. So, what you can do is to let this function return '$null' for those file types which you don't need the numbering schemes.
E.g.
function GetNumSchms
try
@ $drawings = @("DWG","IPN")
if ($drawings -contains $Prop["_FileExt"].Value)
return $null
$numSchems = $vault.DocumentService.GetNumberingSchemesByType('Activated')
#... so on.
@Anonymous wrote:Hello,
