AutoCAD Utility Design Forum (Read Only)
Welcome to Autodesk’s AutoCAD Utility Design Forums. Share your knowledge, ask questions, and explore popular AutoCAD Utility Design topics.
1417 Views, 1 Reply
Standard
I am new with this software and haven't tried it yet. I want to know if overhead's or under ground's Standard cover any specefic areas? is there any way to add specefic municipal standards?
Thank you
1 REPLY 1
jpab
The standard shipping version of AUD comes with the RUS Standards for overhead and underground engineering as well as material ordering for both. However since every utility is different and has their own standards AUD is configurable to almost any standard for both Engineering and Material ordering for overhead and underground.
A side note: The engineering values for the wires used in the shipping version came directly from either Alcan or Southwire so almost every utility should be able to use them as is. (all the utility would have to do is change the assembly name to match their standard)
if you want more information about AUD you can contact Linda Viet
Jim Bower
Linda Veit
lindaveit@spatialnet.net
www.spatialnet.net
”Boost
”Tips
Need installation help?
New Utility Design Category!
The Utility Design forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
