AutoCAD Utility Design Forum (Read Only)
Welcome to Autodesk’s AutoCAD Utility Design Forums. Share your knowledge, ask questions, and explore popular AutoCAD Utility Design topics.
Location Notes
1 REPLY 1
606 Views, 1 Reply
Location Notes
Hello all,
We are looking at moving to AUD2104 from AUD2009 and I am looking for a way to display specific notes for a location (like pole class, crossarm type, etc.)
With AUD2009 we did it with I:Notes and logic in the old .lgk files. Is there a way to do that with AUd2014 ?
Dan
1 REPLY 1
dave.w
Material rules in AUD 2014 support an 'Add note' function which generates material note records. These can be viewed in the Material List Editor and displayed in Work Location block attributes via the Style definition used by the Work Location.
The following help articles have more information:
About Material Note Rules
http://docs.autodesk.com/UTLDESN/2014/ENU/filesAUDUG/GUID-DE33047D-B591-4EF9-B97A-D7E36B70A18E.htm
To Define Work Location Styles
http://docs.autodesk.com/UTLDESN/2014/ENU/filesAUDUG/GUID-79CFBA10-85F3-4D9D-8B30-8214F146D72D.htm
To display notes in the work location block attributes, you'll need to define a rule expression for each block attribute. The rule expression can either lookup a particular note by index, or concatenate the notes into a single text expression.
”Boost
”Tips
Need installation help?
New Utility Design Category!
The Utility Design forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
