AutoCAD Utility Design Forum (Read Only)
Welcome to Autodesk’s AutoCAD Utility Design Forums. Share your knowledge, ask questions, and explore popular AutoCAD Utility Design topics.
Load on One Node
1 REPLY 1
kulfi
577 Views, 1 Reply
Load on One Node
How we calculate the Load on one Point with AUD 2014.
Kulfi
Electronics Engineer
Pind Saudi Arabia
1 REPLY 1
dave.w
in reply to: kulfi
The Load attribute on a service point can be calculated and set using validation rules. It is recommended to create an Expression subrule that evaluates to the calculated value required and then to use that subrule within the validation rule in order to validate and set the attribute using a "Report and fix" rule.
For example, below is a general example for calculating and setting an attribute. In your case, you would be setting the Load attribute:
/Expressions/Real/Electric/Point/Service Point/Calculated Load
    ...calculate your load in the expression
/Validation/Electric/Point/Service Point
     If   [Load]  is not equal to   [Calculated Load]
     Then
           Report and fix   "Load requires updating"   auto-resolve enabled
           Resolution  "Update to calculated load"
                   Update multiple attributes
                          Set attribute  Load  =   [Calculated Load]
In the latest release of the product, this can be simplified by using the Set attribute function directly:
     Then
”Boost
”Tips
Need installation help?
New Utility Design Category!
The Utility Design forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
