AutoCAD Utility Design Forum (Read Only)
Welcome to Autodesk’s AutoCAD Utility Design Forums. Share your knowledge, ask questions, and explore popular AutoCAD Utility Design topics.
kulfi
1831 Views, 3 Replies
Duct
How can we make duct bank show in the attached image.
thanks
Kulfi
Electronics Engineer
Pind Saudi Arabia
3 REPLIES 3
dave.w
in reply to: kulfi
The example image contains what appear to be many telecom and electric ducts. To model this in AUD you need to create 3D Model and Detail blocks for corresponding Segment and structure models. The blocks should be defined with ports defining the offsets/locations of each duct.
To create instances of the model you will need to setup Feature Library or CUI macros which allow the entire collection of ducts (and contained conductors and cables) to be drawn at once, or to use other commands such as AUDADDTOSEGMENT to add them individually to the same segment in the design.
NaderAzem2534
in reply to: dave.w
Please can you show me one practical example so it is easier for me to understand.
thanks
dave.w
in reply to: NaderAzem2534
There should be some examples and details concerning configuration of this in the whitepaper entitled "Detail and 3D Model Creation for Trench and Structures". The whitepapers are accessible on Subscription Center.
”Boost
”Tips
Need installation help?
New Utility Design Category!
The Utility Design forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
