AutoCAD Utility Design Forum (Read Only)
Welcome to Autodesk’s AutoCAD Utility Design Forums. Share your knowledge, ask questions, and explore popular AutoCAD Utility Design topics.
Autocad Utility Design to Map 3d Industry Model
1 REPLY 1
carlos.uribe
562 Views, 1 Reply
Hello Everyone:
I'm trying to export electric network data from AUD to  Map 3D Industry model, the problem is that when I'm working with AUD the features are Drawing Objects in dwg format (However im not sure I if there are some feature classes associated to these elements) so when I'm trying to export to Oracle the attributes associated are not being exported, the tables are created just with the Geometry without data.
Is there any missing step to export from AUD to Map 3D Industry Model (Electric Model)?
Could you help us out?
Regards
Carlos Uribe. Man Sad
1 REPLY 1
pat.reid
in reply to: carlos.uribe
Carlos-
Just found this site, so you may already have your answer. But it sounds like you are missing the step of mapping the features.   A short video of the process can be found at http://blog.spatialbiz.com/customer-samples/
r-
”Boost
”Tips
New Utility Design Category!
The Utility Design forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
