AutoCAD Utility Design Forum (Read Only)
Welcome to Autodesk’s AutoCAD Utility Design Forums. Share your knowledge, ask questions, and explore popular AutoCAD Utility Design topics.
al.williamson.fl
1995 Views, 4 Replies
AUD 2012
When I "create a new design" after entering AUD, drop down menus for in "layout settings" tab for voltages & Status no longer function (they are blank).  I sthis because I am using as "trial" rather than a registered version ?
4 REPLIES 4
The Trial version should function the same as a registered version. It will time-out after the trial period expires.
If the layout settings are blank, it's likely due to the template selected after New Design is launched.
Try using one of the templates included with AUD 2012, like 'RUS-Standards-Imperial.'
Jeff Paquette
Data Management Support Specialist
Thanks Jeff. I selected the IM_ElectricNA which was installed with the product, so I thought it should be good?
If I select the RUS-Standards-Imperial, when I try to assign a coordinate system (FL83-WF) I get an error meassage:-
 "You have to select a coordinate system that has the same unit code with source coordinate system"
the help/training video indicates that when creating a new design, I should be able to set a new coordinate system?
-Al
Here's what I did to get the correct coordinate system issue when trying to use the RUS Standards-Imperial template.
Create new design - used the 'RUS Standards-Imperial" template - left units alone
Switched workspace to 'Map Classic', then assigned desired coordinate system (FL83-WF)
WHen prompted I selected "assign this coordinate system" - the file regenerated no problem
switch back to Utility Distribution - Electric workspace
saved this file as a new template, whcih seems to work fine with the correct/desired coordinate system
-Al
thank you for given a lot information.
”Boost
”Tips
New Utility Design Category!
The Utility Design forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
