Menu | Function | Shortcut | Toggle (Y/N) |
File |
New |
Ctrl+N |
N |
File |
Open… |
Ctrl+O |
N |
File |
Exit |
Ctrl+Q |
N |
File |
Save… |
Ctrl+S |
N |
File |
Save As… |
Ctrl+Shift+S |
N |
File |
Close |
Ctrl+W |
N |
File |
Save image |
Shift+S |
N |
File |
Import Models… |
Ctrl+I |
N |
File |
Import Status Window |
I |
N |
Edit |
Duplicate |
Ctrl+D |
N |
Edit |
Undo |
Ctrl+Z |
N |
Edit |
Delete |
Delete or backspace |
N |
Edit |
Reverse Normals |
F8 |
Y |
Edit |
Show Transform Handles |
H |
Y |
Edit |
Organizer |
O |
N |
Edit |
Copy Transform |
Ctrl+Shift+C |
N |
Edit |
Paste Transform |
Ctrl+Shift+V |
N |
Edit |
Revert Transform |
Ctrl+Shift+Z |
N |
View |
Fit to View |
Ctrl+F |
N |
View |
Borderless Window |
Ctrl+F9 |
Y |
View |
Set Home View |
Ctrl+Home |
N |
View |
Full Screen |
F9 |
Y |
View |
Go to Home View |
Home Alt+Home |
N |
View |
Show View Cube |
N |
Y |
View |
Show Steering Wheel |
Shift+W |
Y |
Select |
Select All |
Ctrl+A |
N |
Select |
Hide |
Ctrl+H |
N |
Select |
Un-hide All |
Ctrl+J |
N |
Select |
Select All Visible |
Ctrl+K |
N |
Select |
Deselect All |
Ctrl+Shift+A |
N |
Select |
Swap Hidden and Visible |
Ctrl+Shift+H |
Y |
Select |
Un-hide Selected |
Ctrl+Shift+J |
N |
Select |
Deselect Hidden |
Ctrl+Shift+K |
N |
Select |
Isolate Seleted |
Ctrl+Shift+L |
N |
Appearance |
Material Properties… |
Ctrl+M |
N |
Appearance |
Accent Lights |
L |
Y |
Appearance |
Material Library |
M |
Y |
Appearance |
Copy Material |
Shift+C |
N |
Appearance |
Paste Material |
Shift+V |
N |
Appearance |
Visual Styles Library |
V |
Y |
Appearance |
Cross-Sections |
X |
Y |
Appearance |
Ray-tracing Control Panel |
Y |
Y |
Appearance |
Decal Order - Move Down |
Ctrl+[ |
N |
Appearance |
Decal Order - Move Up |
Ctrl+] |
N |
Appearance |
Decal Order - Move to Bottom |
Ctrl+Shift+[ |
N |
Appearance |
Decal Order - Move to Top |
Ctrl+Shift+] |
N |
Story |
Alternatives |
A |
Y |
Story |
Behaviours |
B |
Y |
Story |
Create Storyboard Slide |
Ctrl+U |
N |
Story |
Lighting Environment Library |
E |
Y |
Story |
Stop storyboard playback, get out of full screen mode, get out of presentation mode |
Esc |
N |
Story |
Stop storyboard playback |
Esc |
N |
Story |
Play current slide from its beginning |
Shift+F5 |
N |
Story |
Shots |
T |
Y |
Story |
Storyboard |
U |
Y |
Story |
Play Previous Slide |
Ctrl+Left Arrow |
N |
Story |
Play Next Slide |
Ctrl+Right Arrow |
N |
Story |
Play All Slides from start (& go to presentation mode & full screen) |
F5 |
N |
Story |
Create Start to End Shot |
Ctrl+Shift+T |
N |
Story |
Create Still Shot |
Ctrl+T |
N |
Present |
Compare Scenes |
C |
Y |
Present |
Browser Panel |
F11 |
Y |
Present |
Pointer |
P |
Y |
Present |
Presentation Mode |
Tab |
Y |
Present |
Swap Left and Right |
Alt+F12 |
N |
Present |
Previous on Left |
Alt+F5 |
N |
Present |
Next on Left |
Alt+F6 |
N |
Options |
Show Decal Grips |
Shift+D |
Y |
Options |
Show Accent Light Grips |
Shift+L |
Y |
Options |
Show Cross-Sections Grips |
Shift+X |
Y |
Options |
Show Task UI |
Q |
Y |
Options |
Show All (Toggle heads-up display on or off ) |
F10 |
Y |
Help |
Showcase Help |
F1 |
N |
viewport |
Change the increment value (speed) |
= (+) or - |
N |
viewport |
Orbit left or right around center of interest |
Left or Right arrow when "" is NOT active , or . at all times |
N |
viewport |
Orbit |
Alt-LMB
Shift-MMB
Alt-Shift-LMB
F4 (clutch key) -LMB
N |
viewport |
Pan |
Alt-MMB
MMB
Alt-Shift-MMB
F2 (clutch key) -LMB
F2 (clutch key) -MMB
F3 (clutch key) -MMB
F4 (clutch key) -MMB
N |
viewport |
Zoom |
Alt-RMB
Ctrl-MMB
Scrollwheel
Ctrl-MMB
F3 (clutch key) -LMB
Up or Down arrow when "" is not active
N |
viewport |
Orbit up or down around center of interest |
PageUp or PageDown when "" is not active; or ' at all times |
N |
viewport |
Remove objects from selection set |
Ctrl+ click |
N |
viewport |
Add shot with shortcut |
Ctrl+Alt + number |
N |
viewport |
Set a point of interest |
Ctrl+Alt-click |
N |
viewport |
Focus in on a point of interest |
Ctrl+Alt-drag |
N |
viewport |
Add a shot with shortcut |
Ctrl+number |
N |
viewport |
Default Viewport Style (HW with both shadows) |
D |
N |
viewport |
Escape - escape fullscreen, presentation mode, modes, tools, playback, windows, deselect |
Esc |
N |
viewport |
Display normals |
F7 |
N |
viewport |
Pivot Mode |
Insert |
Y |
viewport |
Walk incrementally to the left or right |
Left or right arrow when "" is active |
N |
viewport |
View shot you have set |
Number or Alt+number |
N |
viewport |
Shift viewing position up or down |
Page Up or Page Down when "" is active |
N |
viewport |
Ray tracing |
R |
N |
viewport |
Snap |
S |
N |
viewport |
Add objects to selected set |
Shift+ click |
N |
viewport |
Walk forward or backward |
Up or Down arrow when "" is active |
N |
viewport |
Previous view = next view |
Alt+Left arrow Alt+Z |
N |
viewport |
Next view = previous view |
Alt+Right arrow Alt+Y |
N |
Keyframe Properties |
Add a new keyframe (in keyframe window) |
N |
Update selected keyframe (in keyframe window) |
N |
Delete selected keyframes (in keyframe window) |
K |
N |
Pivot Mode |
Toggle between center and natural pivot |
Ctrl+Insert |
Y |
Pivot or snap mode |
Drop pivot to bottom |
G (while holding down S) |
N |
