Show only
Search instead for
Unofficial solution for running TB Administrator on Windows 7 (64-bit)
I have just recently discovered that some .NET applications developed in 32-bit environments (e.g. TB Administrator) report errors when trying to get run in a 64-bit Windows environment.
One of the unofficial solutions is to set to default the 32-bit CLR and use it. Just go co Command line (CMD) and run the following:
