Topobase
Member
aarathik
Message 1 of 5 (265 Views)
Topobase web
265 Views, 4 Replies
10-31-2009 03:38 AM
When I'm trying to publish the map through mapguide, I'm able to view the map along with the list of layers displayed in the legend pane to the left but the topobase explorer is not loading.Can any one tell where to configure to view document explorer, workflow explorer, plot explorer on web.
Member
petrf
Message 2 of 5 (265 Views)
Re: Topobase web
11-01-2009 12:59 PM in reply to: aarathik
Hi, Topobase Web has a template. Just load mapguide package "c:\Program Files\Autodesk\MapGuideEnterprise2010\WebServerExtensions\www\TBWeb\Sample_MapGuidePackage\Topobase Web Layout Package.mgp" and use Mapguide Studio.
Member
aarathik
Message 3 of 5 (265 Views)
Re: Topobase web
11-02-2009 09:58 PM in reply to: aarathik
Thank You for the response, I have loaded electric_NA data as u said from the path
C:\Program Files\Autodesk\MapGuideEnterprise2010\WebServerExtensions\www\TBWeb\Modules\Electric_NA\MapGuide Package
and when i'm trying to view it in browser its displaying "You are not logged in !" in the topobase Explorer tab .I have loggedin Topobase client , opened the workspace where I loaded Electric_NA data(this data i have loaded from the dump that was provided) and connected to mapguide thru client and tried to view the web from it, but its giving the same error.
where do i need to login?
Member
petrf
Message 4 of 5 (265 Views)
Re: Topobase web
11-03-2009 11:43 PM in reply to: aarathik
Hi, I guess you are interesting in Topobase Electric NA module. Try these steps.
• Load mapguide package Topobase Electric NA Package.mgp
• Create new workspace.
• Import TB2010_EL_NA_102.dmp in it.
• Recreate spatial indexes.
• Set web layout for workspace
      AJAX .WebLayout
      Fusion .ApplicationDefinition
• Check database connection
      Library://Topobase Electric NA/Data/Topobase_1.FeatureSource
• Finally login TBWeb http://server/mapguide2010/TBWeb
Member
aarathik
Message 5 of 5 (265 Views)
Re: Topobase web
11-24-2009 09:40 PM in reply to: aarathik
Thank you for the help. I got it.
