Topobase
Valued Contributor
spatialnetbrek
Message 1 of 9 (913 Views)
Topobase Web - IIS Installation
913 Views, 8 Replies
03-24-2010 05:53 AM
While reviewing the Topobase installation and configuration guide I see a note regarding the installation of IIS before the Topobase client as outlined in the following:
"NOTE IIS must be installed before the .NET framework, which is installed by default
with Topobase Client. Make sure that you install IIS first, before installing Topobase
Client or Topobase Web."
Unfortunately I did not see such a note prior to installing the Topobase client so I'm wondering what effect this will have and what if any workarounds must be accomodated.
Thanks in advance!
Brek
Shatohin
Message 2 of 9 (913 Views)
Re: Topobase Web - IIS Installation
03-25-2010 12:08 AM in reply to: spatialnetbrek
I had an experience in installing IIS after TB Client and I didn't notice any negative effect. But I can't say that in your case all will be OK.
Anyway it's better to follow Autodesk instructions.
And you really must install IIS prior to TB Web. Edited by: Shatohin on Mar 25, 2010 7:08 AM
Valued Contributor
spatialnetbrek
Message 3 of 9 (913 Views)
03-25-2010 05:28 AM in reply to: spatialnetbrek
Thanks again Shatohin,
I also had a previous experience installing IIS after TB but before TB Web. The only issue I then encountered was that I was unable to login to the admin screen. It was suggested that the issue may have been that the .aspx extension should be registered as executable. I was unable to complete this and my machine crashed about a week later. I can always restore the image taken before the TB install if it comes to that.
Thanks again for your assistance and have a good day!
Brek
Shatohin
Message 4 of 9 (913 Views)
03-25-2010 06:40 AM in reply to: spatialnetbrek
Hi Brek,
If you installed IIS after TB Web it shouldn't work.
A virtual directory is created in IIS while TB Web Extension installation. So if you are familiar with IIS you can create a virtual directory and make all necessary setting manually (even if you installed IIS after TB Web). If you are not just reinstall TB Web. It doesn't take much time.
Valued Contributor
spatialnetbrek
Message 5 of 9 (913 Views)
03-25-2010 06:50 AM in reply to: spatialnetbrek
I have not installed TB Web, only the client.
Valued Contributor
spatialnetbrek
Message 6 of 9 (913 Views)
04-18-2010 12:33 PM in reply to: spatialnetbrek
Have successfully installed IIS and TB Web.
Thank you for your help
New Member
bheasley
Message 7 of 9 (913 Views)
04-20-2010 03:33 PM in reply to: spatialnetbrek
I am running Windows Server 2003 SP2 Standard Edition w/ IIS installed but when I go to install TB Web I receive the following error:
"The required version of IIS was not detected on your machine. Please, exit and install the required IIS version on this machine"
I am not sure what TB Web is requiring but IIS is most definitely installed.
Shatohin
Message 8 of 9 (913 Views)
04-21-2010 03:10 AM in reply to: spatialnetbrek
Try to reinstall IIS with Add or Remove Programs tool
Valued Contributor
spatialnetbrek
Message 9 of 9 (913 Views)
04-21-2010 04:55 AM in reply to: spatialnetbrek
Thanks guys,
I've been able to resolve this issue, thanks for your feedback!
Brek
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
