While reviewing the Topobase installation and configuration guide I see a note regarding the installation of IIS before the Topobase client as outlined in the following:
"NOTE IIS must be installed before the .NET framework, which is installed by default
with Topobase Client. Make sure that you install IIS first, before installing Topobase
Client or Topobase Web."
Unfortunately I did not see such a note prior to installing the Topobase client so I'm wondering what effect this will have and what if any workarounds must be accomodated.
Thanks in advance!
Brek
