Topobase (Read Only)
Welcome to Autodesk’s Topobase Forums. Share your knowledge, ask questions, and explore popular Topobase topics.
Topobase Web 2010 Login
3 REPLIES 3
spatialnetbrek
1064 Views, 3 Replies
After following the guidelines for Topobase Web installation as described in the "topobase_2010_install_configuration_guide.pdf"; I attempt to launch using the following URL: http://localhost/MapGuide2010/TBWeb/login.aspx
Instead of the login page, I see the code behind the login page.
Any ideas as to what I've not configured correctly?
Thank you in advance,
Brek
3 REPLIES 3
Shatohin
in reply to: spatialnetbrek
Look at your IIS settings.
.aspx extension should be registered as executable.
Sale05
In case they aren't registered go to Windows features->IIS->WWW Services->Application Development Features and add asp and asp.net (I added everything)
Aleksandar Edited by: Sale05 on Mar 16, 2010 11:51 AM
Have successfully logged into TB Web.
