Hi
I am new to Topobase. I have installed TB client 2011 64 bit version on Win 7.
I need clarification on how rights (Create,Delete, Update), Users and roles are related in TB.
I logged in as TBSYS in TB administrator and created a workspace and a Water document using the in built template. Later i created a user group CWEDITORS i.e CleanWater Editors and assigned the workspace that i created earlier to this usergroup.
Then i created a user, say U1, and assigned it to CWEDITORS. In Security Administrator i created a ROLE for which a password was also assigned and using the GUI i assigned the CRUD previliges to this role.
1) What i actually wanted was to assign the roles (created using TB Security administrator) to either the user groups or users.(Is this possible) ? It is not clear how to do this as the roles are defined at oracle level and my understanding is that the users are created at application level (i.e users like TOPOBASE, U1)
2) What is a guest document? Can someone explain more clearly?
Regards
Govind
Hi
Thanks for ur response. As i had mentioned earlier i am using 2011
In the Security Administrator i didnt see any provision to Assign the roles to a Group or user.
Am i missing something?
Regards
Govind
Hi Govind,
You should create a new workspace and add a guest document there. After that you will be able to configure user rights at workspace level.
BR
Alexander Shatohin
