Topobase
Active Member
ramandeep_TCS
Message 1 of 3 (78 Views)
topobase admin locked
78 Views, 2 Replies
03-11-2008 01:47 AM
when i try to start topobase admin then i get the error message that " your account is locked".
how to solve this problem
Member
hristo_tomov
Message 2 of 3 (78 Views)
Re: topobase admin locked
03-13-2008 06:11 AM in reply to: ramandeep_TCS
i had the same problem ... and that's how i solved it - > http://discussion.autodesk.com/thread.jspa?threadID=649445
Arnab Ganguly
Message 3 of 3 (78 Views)
03-26-2008 11:00 AM in reply to: ramandeep_TCS
Here is a little tip if you are using Topobase in a test environment and you are using the sample data that comes with the product or if your account is getting locked frequently due to incorrect logins.
Here is the workaround:
Log into SQLPlus as your system user and run the following
CREATE PROFILE DEFAULT_TOPOPASE
LIMIT FAILED_LOGIN_ATTEMPTS UNLIMITED;
ALTER USER TBSYS PROFILE DEFAULT_TOPOBASE;
Post to the Community
New Post
Need installation help?
