Topobase (Read Only)
Welcome to Autodesk’s Topobase Forums. Share your knowledge, ask questions, and explore popular Topobase topics.
topobase admin locked
2 REPLIES 2
317 Views, 2 Replies
when i try to start topobase admin then i get the error message that " your account is locked".
how to solve this problem
2 REPLIES 2
i had the same problem ... and that's how i solved it - > http://discussion.autodesk.com/thread.jspa?threadID=649445
Here is a little tip if you are using Topobase in a test environment and you are using the sample data that comes with the product or if your account is getting locked frequently due to incorrect logins.
Here is the workaround:
Log into SQLPlus as your system user and run the following
CREATE PROFILE DEFAULT_TOPOPASE
LIMIT FAILED_LOGIN_ATTEMPTS UNLIMITED;
ALTER USER TBSYS PROFILE DEFAULT_TOPOBASE;
