Topobase (Read Only)
Welcome to Autodesk’s Topobase Forums. Share your knowledge, ask questions, and explore popular Topobase topics.
TBWEB problem starting
2 REPLIES 2
Sale05
584 Views, 2 Replies
I was working on TBweb 2010 (Windows Vista, IIS 7), trying some things. Everything was fine. Anyway in the middle of that there was no response from software. When I go to TBWEB (http://localhost/mapguide2010/TBWeb/login.aspx) I just get empty white page. Server doesn't respond, status bar says Done. Ok, I tought I made something wrong with software, tried to recover everything back to normal. No chance there.
After that, I uninstalled whole TBweb, all .NET frameworks and IIS. Installed all back, first IIS, second .Net framework and at the end TBweb, I know that order is important. Tried this many times, I don't know how many anymore, but still I get blank white page.
One interesting thing is that when I publish from client I can see what I published like "Slate". I am really getting desperate, cleaned registry couple off time, changed frameworks...but nothing.
It just seems that TBWEB app with splash screen can't start. I can't get to the login.aspx page. IIS is working ok with everything else, even with TB slate. None of the .aspx files in TBWeb is responding.
Any idea is appriciated! Thanks!
2 REPLIES 2
freiharts
in reply to: Sale05
Hi all together,
i have nearly the same problem. TBWeb is not working anyway and has never worked on my Laptop using Vista Enterprise and IIS 7.
right now I reinstalled it completely several times and found no solution.
I tried it with installing IIS 6 compatibility manager, changing directories, directory grants, ...
Have you found a solution Sale05?
has anyone a new idea?
thanks,
Simon
Simon Freihart
Premium Support Specialist
Sale05
in reply to: Sale05
My solution was to completely reinstall OS and everything else. Until I didn't do that, TB web didn't have a chance to work. :( Edited by: Sale05 on Nov 16, 2009 12:51 PM
