Show only
Search instead for
After 10 trials to log with the wrong password in TBSYS account,
the account was locked. What is the way to unlock TBSYS account and set a new password?
Thank you in advance.
So.. TBSYS account can be change like normal Oracle accounts. For example:
1. Login in SQL Plus (with SYSTEM)
2. unlock account with "alter user TBSYS account unlock;"
3. change the password, if you need with "alter user TBSYS identified by TBSYS;"
Here is a little tip if you are using Topobase in a test environment and you are using the sample data that comes with the product or if your account is getting locked frequently due to incorrect logins.
Here is the workaround:
Log into SQLPlus as your system user and run the following
CREATE PROFILE DEFAULT_TOPOPASE
LIMIT FAILED_LOGIN_ATTEMPTS UNLIMITED;
ALTER USER TBSYS PROFILE DEFAULT_TOPOBASE;
