Topobase (Read Only)
Welcome to Autodesk’s Topobase Forums. Share your knowledge, ask questions, and explore popular Topobase topics.
TB 10 ereases display models!
2 REPLIES 2
cafeineman
531 Views, 2 Replies
I'm using TB 10 and when I try to save my display model, program almost always closes (ok, that's not too serious) and very often it also deletes the tbdm file! I mean That I loose all my work. Am I the only one in this case? does someone have a solution? (exept make a copy of the model display folder in another place several times a day)
2 REPLIES 2
luekewille
in reply to: cafeineman
I had the same problem. Be sure, that the C:/TEMP-Folder is empty or not bigger than 4 GB. 4 GB is the maximum in a 32-bit-system.....
Frank!
romaine
I have similar problem with display model. I cannot create folder in folder and when I set in map1.tbdmmap in false and open display model always layer is expand. I have cca 70 layers.....if all layers is open/expand....it is no good
