Topobase (Read Only)
Welcome to Autodesk’s Topobase Forums. Share your knowledge, ask questions, and explore popular Topobase topics.
Spatial Report Design TOPOBASE
1 REPLY 1
2316 Views, 1 Reply
Hy!
I'am new to topobase administrator and i'm trying to create a spatial selection report.
i'm using gas data model and i want to select all pipes that have an atribute smaller than a certain value. I want to print all the features but each on a different page witn zoom extends and and havind some atributs listed at the bottom of the page.
do you have a better idea rather than using Topobase spatial selection reports?
Thanks in advance.
1 REPLY 1
deetersmith
You may already have your answer but a spatial report is an easy way to get your answers.  I assume you will be choosing small portions of your system not the complete system since you are using spatial.  Make sure you use style: Formular to get each on a separate page.  Module Name must be set to Topobase.SpatialExportTool and ParameterID=1 and SpatialMask = anyinteract.
I hope this helps.
