Topobase
Active Member
b.banzer
Message 1 of 5 (1,930 Views)
Restrict access on commands for user groupes on specific feature classes
1930 Views, 4 Replies
04-16-2012 01:31 AM
I am creating an industry model in which I have several feature classes and different user groups.
For security reasons, some user groupes should get read only access on some objects but full access on some others.
In the user interface, I can remove the function "New Record" for example for a user group, but that means that it is not available in all the forms.
Does anyone have an idea how I could solve that problem?
Thanks in advance.
Hi Bob,
you can create different toolbars and then assign a specific toolbar to a form. It's is a bit confusing and I'm not sure whether I have fully understood the idea behind it or not. Because I haven't used it yet but just checked how it works in general I cannot gurantee it's 100% correct.
I do not have the english version at hand - so the terms I'm refering to might be bit different in the application itself.
1. open a workspace/project
2. expand the document node and look for "user interface" node
3. switch to the Forms tab
4. select the user group you want to assign the new toolbar to
5. create a new entry and disable "new record"
6. select the Form-Designer node and select the feature class
7. copy the existing form
8. open the copied form
9. open the form options (in menu "Designer")
10. assign the newly created toolbar to the form
11. close form
12. assign form to group
Rob
Robert_Fritz
Message 2 of 5 (1,927 Views)
Re: Restrict access on commands for user groupes on specific feature classes
04-17-2012 06:05 AM in reply to: b.banzer
in this case - why don't you create a separate form for each user group?
Rob
http://raumpatrouille3d.blogspot.ch/
Active Member
b.banzer
Message 3 of 5 (1,922 Views)
04-17-2012 06:45 AM in reply to: Robert_Fritz
Rob
Hi Rob,
that was initially my plan, but I can't figure out, how I can disable for example the "new record" function in one form but not the other.
Bob
Robert_Fritz
Message 4 of 5 (1,920 Views)
04-17-2012 07:07 AM in reply to: b.banzer
Hi Bob,
11. close form
Rob
Active Member
b.banzer
Message 5 of 5 (1,914 Views)
04-17-2012 11:30 PM in reply to: Robert_Fritz
Hi Rob, thanks a lot! I just tried it and in the MAP client it works like a charm. You saved my project. Bob
