Topobase
sirofthedark
Message 1 of 3 (143 Views)
Problem with Examples in VB.Net
143 Views, 2 Replies
04-11-2007 11:52 AM
Hello
I would like run the samples in topobase with VB.Net. Some examples run like stand alone applications , but some run with an application expecifics.
I tried with acad.exe and TopoBaseadminsitrator.exe but it can't work. I can´t run the examples.
I thank in advance any comment you can give me.
Arnab Ganguly
Message 2 of 3 (143 Views)
Re: Problem with Examples in VB.Net
04-11-2007 01:04 PM in reply to: sirofthedark
Hi there
Which examples are you having problems with?
Are you able to compile the projects without errors?
Also, do you have the developers guide that ships with the product. It can be found in the Autodesk Topobase Client 2007\Manuals folder. There are a couple of steps that you need to be aware of while running the samples.
Regards
Arnab
sirofthedark
Message 3 of 3 (143 Views)
04-11-2007 02:55 PM in reply to: sirofthedark
Thanks a lot!!!!
This is what i required
