Topobase (Read Only)
Welcome to Autodesk’s Topobase Forums. Share your knowledge, ask questions, and explore popular Topobase topics.
Pls help, for data migration from dwg file and oracle schema
1 REPLY 1
271 Views, 1 Reply
I have two basic questions, which answers I didn't found in Topobase help and tutorials.
1. I have drawing data in some.dwg file (with parcels).
How to create and convert this data to topobase workspace?
2. I have oracle schema (not spatial data, tables with information about parcels like owner, type).
In some tables, I have centroids IDs. Also I have centroids in the some.dwg file.
How I can make the connection between both?
Thank you in forward!
1 REPLY 1
Hello Cesara,
For example you can use Map3d Geospatial to input dwg objects into the Oracle scheme. In the FDO tool you can see option that are giving you ability to put some of the attribute data also (you can use it for some key fields or etc). I think you can use the same scheme which you already have with the data. With Topobase 2009 Administrator you can convert this schema to Topobase document, and than again in the Administrator you can create relations between the objects key fields and the data tables (from the Form Designer).
Good Luck
