Topobase (Read Only)
Welcome to Autodesk’s Topobase Forums. Share your knowledge, ask questions, and explore popular Topobase topics.
obtaining TopoBase user and making filter
2 REPLIES 2
413 Views, 2 Replies
hello forum! I have some specific questions about using the API for TopoBase:
- How can I obtain the user (created using the TopoBase Admin) currently logged with VB code? If possible, how to obtain the user id?
- How can I make a filter, using VB code, to obtain a subset of the information when loading the "show form" dialog?
Thanks for any help
Irene Rangel
2 REPLIES 2
andreas.boos
Hi Irene
You can use following code to get the user name and use id
(I suppose you are doing this in some plug-in, ‘Me’ here represents the plug-in instance)
Me.Application.UserName
Me.Application.UserId
You can use following code to filter the data in the form:
Topobase.Forms.Dialog dialog = Me.Document.Dialog.Items(featureClass)
‘ Build a sql where clause formatted like: ‘fid in (1, 2, 3)’
‘ You can use it to filter the data
String whereClause = Topobase.Data.Provider.BuildInCondition(…)
dialog.Show(whereClause)
Hope this helps
Best regards
Andreas
Thanks for the responses. They helped a lot to solve my problems.
Irene Rangel
